-Skin Name Extreme (PROMIX)
-Supported 2 Decks
- Resolution 1440x900
- 6 Skins in 1 Packege
- Audio-Mix mode,Video-Mix mode,External-Mixer mode & Library mode to see more songs in the browser with basic functions
Features:
Left & Right Deck
- 7 Wave views
- Big Info Display & Spinners + No Spinners
- Several panels can be selected from (Effects,Samplers,Loops,Cues,Scratch,VideoFX,Track Inf.) Buttons
- FX Pannel (Main Effect, 5 fx Slider + name & percentage, 4 fx buttons) + (3 FX Slot + 3 fx Slider)
- Sample Pannel (Main sample and all options + 6 samplers slots) (3 sampler slot and limited options) (12 sampler slot play stop & stutter)
- Loops Pannel (loop size,loop move,loop length 1/32 to 64 beat,loop in,loop out loop exit, reloop & loop double,half)
- Cues Pannel ( 8 Hot cues + 8 set cues & delete )
- Scratch Pannel (Scratch wave,mirrored & classic )
- Video FX Pannel (Main video fx Button + 5 fx slider & percentage,mini video master aut )
- Track Inf. Pannel (Loaded song INF. & Browsed song INF.)
- Browser Font resize
- Center panels can be selected from (Mixer,video,scratch)
-Update: fix the loop, text it's not appear on the video skin & Add. video crossfader
In case you need to comment or report anything about the skin please visit the relative topic.
http://www.virtualdj.com/forums/174949/VirtualDJ_Skins/New_skin_(2deck).html
Skin created by dj lunatico
Enjoy it!
    -Supported 2 Decks
Features:
Left & Right Deck
- 7 Wave views
Enjoy it!
geposted Sun 20 Jul 14 @ 6:15 pm
