Anything is possible ;-) well mostly ..
But since the Hz is not part of database or filter query currently, it will have to wait and see. . what future holds :)
geposted Thu 29 Nov 18 @ 8:12 pm
Thank you, and here is a picture that shows very well that the frequencies can help us to see the false bitrates
https://plus.google.com/u/0/photos/photo/102359745121257562808/6629555979251102658
geposted Fri 30 Nov 18 @ 7:48 am
does your app do a better job for helping find lost files in the virtual folders.. as I got a bunch all over the place and id like to import old copies of my vdj folders I found backups import it finds it and then I can delete the backup copies..
as I also find the search for the missing files in vdj I have to put a weight on the enter key to goto the next one.. but when it cant find it sits there.. I was hoping for an auto skip if it cant find
currently vdj been a renaming..renaming infinite loop.. and I trying now now I move all my files from one Drive to another drive while in VDJ to see if it will force corrections and get out of this endless loop
geposted Tue 09 Jun 20 @ 2:13 pm
update 2020
geposted Mon 29 Jun 20 @ 12:44 pm
Besteht hier auch die möglichkeit das Addon auf Deutsch umzustellen ????
geposted Tue 07 Jul 20 @ 1:30 pm
UPDATE 2021 WITH HASHTAGS ETC
geposted Fri 04 Jun 21 @ 5:57 pm
Pas bien compris l'utilité du plug-in. Si qq peux éclairer ma lanterne
geposted Fri 11 Mar 22 @ 4:23 pm
Can you review this thread and see if this can some how be done through this add-on?
https://www.virtualdj.com/forums/248597/General_Discussion/My_sidelist_idea__Seems_even_RekordBox_is_in_our_forum_.html?page=1
geposted Sun 16 Jul 23 @ 12:41 am
it can't
geposted Sun 16 Jul 23 @ 12:58 am
