Forum: Addons
Topic: My Library - Page: 1
My Library - the essential music collection tool for your VirtualDJ 8 database, with smart folders to quickly locate tracks in your collection by different parameters, as well as tools for managing files in database.
Drag and drop 2 files, and you instantly have a powerful database tool for your collection
Instructions on how to use inside the zip.
For comments/Questions etc:
http://www.virtualdj.com/forums/189385/VirtualDJ_Plugins/MY_LIBRARY.html
geposted Mon 21 Jul 14 @ 11:49 am
Im getting an error when I try to install the new version.. "Installation Error 14"
I also get the installation error 14. Any help please
We removed the Installers . Please use the Download button and read instructions inside the zip
My install of Virtual DJ 8 doesn't have a "folder" folder. I manually created it and dragged the My Library stuff there, but it doesn't work. Please help. What to do?
Okay. I found it. It should not go to a folder "FOLDER" where the program (executable) resides on your computer, but under the VitualDJ folder "Folders" as like <drive>:\username\Documents\VirtualDJ\Folders ... this is not what the instructions are very clear about.
This addition My Library, should come standard with the program ... This is a fantastic addition ... Many Thanks! I would recommend it to the Virtual DJ developers to add to next version.
Thanks for creating this - it's amazing and making my job SO much easier :)
Any way to make some like it for vdj 7??
thats not possible, sorry
thanks for the help....
Why under Genre folder is not showing my custom's name like ... Salsa ??? Thx
Hi Dj in Norway, very nice add on, respect.
I've noticed that the folder in "added" new to cu cache isn't working for me.
I'm on the latest beta vers.
thx for your hard work
ray
Awesome add-on! Much respect to Dj In Norway for creating this. I just have one question about the "Tools" section. When going into the "No ______" folders to clean up those files (Artist, Title, BPM, etc.), do I have to manually tag each file by typing in the information needed.....or is there a way that these files can be quickly recognized & tagged somehow via the internet? That seems to be my only issue so far. If I think of anything else, I will be sure to let you know. Thanks again for creating this....VERY helpful :-)
KaraokeBOM
I've put in the my folders and it show up on the tree but can not open nor does it show any music. What am I doing wrong?
okay it is working but I have to close and restart vdj8 about 4 times for it to do so
What about songs with no cues points ?
why can't we see the GAIN (db) in the library ?
Cue point is not an actionable item in the list for filters.
Gain is also not an actionable item. I'm not really sure why you would need to search by gain either.
I did it VDj-7 isscanned=0
41%
