Forum: Addons
Topic: My Library - Page: 2
I see that there is an update to the "My Library" add-on! Can you please tell me what has changed?
Yeah, I'd like that info too please. This is the BEST VJD addon BTW, great work - thanks.
M.
Im not sure but maybe its more in tune now after BUILD 2821came out.
it was just an update to the server certificate, so that downloads meet new standards for Mac/windows.
But there will be an update soon, working on adding some updated stuff to it
Support staff wrote :
My Library - the essential music collection tool for your VirtualDJ 8 database, with smart folders to quickly locate tracks in your collection by different parameters, as well as tools for managing files in database.
Drag and drop 2 files, and you instantly have a powerful database tool for your collection
Instructions on how to use inside the zip.
For comments/Questions etc:
http://www.virtualdj.com/forums/189385/VirtualDJ_Plugins/MY_LIBRARY.html
To greek music the library can not workonly in english music.
Is it difficult to make the library in greek language
ddj sb2 rnb fridays
Hi,
Great plugin, I use this loads.
However, I've transferred all my music to an external hard drive and since then, all of the filters in the My Library folders have somehow become duplicated. Is this something easy to fix, or do I have to go through each folder and delete all of the duplicate filters?
I hope someone can help.
Thanks
example of duplicates...
duplicates not shown in finder (Mac)...
Open your external HDD on finder.
Go to /VirtualDj/folders
Locate the "My Libray.vdjfolder" file and "My Library.subfolders" folder
Move them to Trash
Done!
Worked like a charm. Big thanks for this add-on!!!
similar Bpm (live) in the My Library addon is added to my sidelist with add shortcut...but it doesnt automatically adjust tracks with new track loaded. You have to click the fold icon to change it. Is there a way to have this done live.
good job :)
good.)
tensink wrote :
Okay. I found it. It should not go to a folder "FOLDER" where the program (executable) resides on your computer, but under the VitualDJ folder "Folders" as like <drive>:\username\Documents\VirtualDJ\Folders ... this is not what the instructions are very clear about.
Entschuldung, Bitte an Alle! Aber wenn ich das runter lade, in welchen Ordner muss ich das denn entpacken ???
I'm just starting with VDJ. A fellow DJ advised me to add "my library". But I think I'm overlooking something or thinking the wrong way. But i just can't get my library in VDJ. I have a mac. I can only open or show content of package. If I drag it to VDJ in the application it pops up somewhere else.
I tried dragging it into the package which was allowed in the end, but nothing.
I tried dragging it into the folder in the documents folder. Saw lots of other VDJ folders there, but nothing... So now I'm out of options I can think of...Help appreciated.
Maybe Rune (dj-in-norway) can do it with "My Library"
A range indicate between 0khz to 22khz in the add-on ?
It's not necessary, I have not explained myself very well, I am not bilingual
I bring new ideas and your answer that "This will never happen whit Virtual DJ"
An idea received can bring another, but surely not with a person like you that technology will advance the most not the way you treat customers!
I'm never ignorant of anyone, if you're not more patient with people and not a developer, you do not like your job, change it !
82%
