Hi,
I have vob video files (videoclips and karaoke) that play fine with VDJ 7.4.1 but not with VDJ8 (on the same PC with XP).
On VDJ8, some of these files play with only the sound but no video! And some others don't play at all (and some others play fine).
No problem with these same files with VDJ 7.4.1
Is it a VDJ8 bug?
Is it a VDJ8 bug?
geposted Mon 21 Jul 14 @ 1:04 pm
We cant fix something if we cant reproduce it. So, if you have any kind of files that dont play as expected, please upload one to a server (or dropbox) and share the link (or pm me if you dont want to share it in public)
ty
ty
geposted Mon 21 Jul 14 @ 7:49 pm
I have the same problem with some old promo only videos, e.g. get low from urban mix volume 3
geposted Mon 05 Jan 15 @ 10:35 am
here it is reversed...
vob files and vdj8 works perfect, the same file in vdj7 wont work. audio is ok but picture stutters
geposted Mon 05 Jan 15 @ 11:57 am
Atomix will need to know how they're encoded. The codecs are internal to VDJ 8 but not to VDJ 7.
geposted Mon 05 Jan 15 @ 12:03 pm
in vdj 7
vob. = Video Decoder
after vdj8 install this no longer work in vdj7
geposted Mon 05 Jan 15 @ 12:40 pm
This video works in vdj7 but not vdj8 (sent to design team to consider)
https://www.dropbox.com/
geposted Mon 05 Jan 15 @ 6:36 pm
Bug is reported.
It should normally allow the file to stream, since it seems too large to load in memory.
It also appears that it incorrectly calculates the Length (remain time).
Anyways, we will have news soon.
geposted Mon 05 Jan 15 @ 6:49 pm
Work around for me. I noticed the (Windows Explorer) properties of the video ripped with VDJ Rip DVD shows the video length is over 26 hours when it is actually just a few minutes. All the old videos ripped with the VDJ Rip DVD that show the video length is over 26 hours are ones that will not play the video in VDJ8 only and trigger the excessive memory error. I found I can rip those videos with a correct video length using SmartRipper and then it will play in VDJ8.
geposted Sun 25 Jan 15 @ 2:22 pm
So did this ever get fixed? It's the same issue on a mac
geposted Fri 09 Oct 15 @ 5:24 pm
Your issue is a different one and will be fixed in the next available build.
geposted Sat 10 Oct 15 @ 10:19 pm
I have the same problem with the file mpg
geposted Mon 19 Oct 15 @ 8:26 am
Try using build 2500.
geposted Mon 19 Oct 15 @ 8:09 pm
Convert more than 500 files mpg to mp4 took me two days, now everything ok :)
geposted Tue 20 Oct 15 @ 4:30 pm
I have installed a second VDJ 8 version 2441.1067 for win xp, here all file types work properly
geposted Wed 21 Oct 15 @ 5:34 pm
