is there any way of changing the jog wheel sensitivity on ddj sx ? i have virtual dj 8 on 2 laptops one as a back up, on one the sensitivity is like a cdj on vynll mode the other is like cd mode. i would like them to be more like cd mode as the tiniest of pitch bends on the platter sends the track flying.
thanks
thanks
geposted Mon 21 Jul 14 @ 3:32 pm
Jogwheel sensitivity in each mode can be adjusted in CONFIG -> Options
Tick 'Show advanced otions' and then search for jog to see the jogwheel related options.
geposted Mon 21 Jul 14 @ 4:39 pm
hi buddy, the two small buttons at the front that you have by the right of your ddj sx, are called Touch Sensor Level, are to set the sensitivity of the jog
geposted Fri 22 Aug 14 @ 10:05 am
