Topic: Import iTunes Ratings
The import of iTunes ratings whose song name (filename) contains such as letters â, è or é does not work.
edit: it´s on Mac Version. I didn´t try it with Windows version.
geposted Tue 22 Jul 14 @ 12:46 pm
Hello,
this problem still exists. It is also with letters like ö, ä and ü and in album name as well, not only artist and title.
Greets Björn
Still no improvement after the latest udate :-(
if iTunes isn't writing the info to the tags it won't be imported
use a program like mp3tag to see if iTunes is actually put it in the id3 tag of the file
The Import iTunes ratings context option was indeed made to import ratings from the iTunes database file, even when they are not written to the tag.
A bug was indeed found with importing ratings of some files on mac, and this will be fixed in the next build.
It works. Thumbs up!
