Pioneer DDJ-SR official mapping files for version 8 have been updated to support the PAD PLUS mode
The PAD PLUS mode can be fully operated using :
- the latest beta build 1897
- the latest controller's version (builds ending at .738 (or higher)
- the unit is switched to Serato mode
If you dont switch the unit to Serato mode, it will be still functional (as it used to be).
If you dont wish to use the beta build, and need to wait for the public one, you can still use the unit on the "Other DJ application" mode (still functional)
An Operation Manual of the default mapping is available here.. https://virtualdj.com/documents/Pioneer%20DDJ-SR%20VirtualDJ%20Operation%20Guide.pdf
geposted Wed 23 Jul 14 @ 8:39 pm
Thanks will grab the latest beta
geposted Sat 26 Jul 14 @ 5:31 pm
Thanks for the update. I have read the instructions and has the mapper, now not got some of the shift parameter function? As couldnt see it in the manual and now doesnt appear to be working?
Example when on hot cues - press shift and left or right would adjust the cbg , but it doesnt seem to be working, is it the new mapper? or have i done something?
Also as a backup how do i install the ddj sr mapper on vdj 7.41?
Thanks
Thanks
geposted Tue 29 Jul 14 @ 4:18 pm
We are trying from now on, to map the devices according to the silkscreen and the "obvious" and reasonable functions.
so , yes the SHIFT +PARAMETER function to adjust the cbg is removed, and the operation guide of the unit doesnt mention anything about a cbg action either. It makes no sense to have such a function to the hotcues mode. What does adjust CBG have to do with the Hotcues anyways ?
If you still need that action back, you can still assign them and create a custom mapping of course.
Keep in mind that the updated mapping files and the PAD PLUS mode support is ONLY for version 8. The files of version 7 have not been updated and will not, as there is no way to support this mode with the available actions/features of version 7.
geposted Tue 29 Jul 14 @ 4:59 pm
Thanks for the reply.
I only ask as the skin you created, shows the shift functions as mentioned, so now doesn't tie up with the skin (DDJ-SR). Which confused me as only got the ddj-sr yesterday and have a ddj-sx as well.
But like you say, cbg has nothing to do with hot cues. Thanks for the update and look forward to using it more.
geposted Wed 30 Jul 14 @ 4:41 am
Will you be updating the skin to incorporate the pad plus mode and the changes? I know you are busy.
Thanks
Thanks
geposted Mon 04 Aug 14 @ 5:27 am
Why cant I download this mapper?
geposted Mon 25 Aug 14 @ 4:42 pm
You will need to purchase a Pro Infinity license in order to download the mapper and use the device with version 7.
For version 8, you can test the unit with the Home Free version, but requires a PLUS or a Pro Infinity license in order to fully use the controller (without a license the controller will work for 10 minutes each time you restart VDJ)
https://virtualdj.com/buy/
geposted Mon 25 Aug 14 @ 10:19 pm
djDAD
Is there a way we can change the level of deck 3 & 4 to 100% during start-up It always 0% when opening V8 with SR connected. I tried it on ONINIT but seems don't get it correctly.
geposted Fri 05 Sep 14 @ 1:42 am
no i am afraid that those are set to 0% from the unit (firmware itself), but why would you want something like that ?
geposted Fri 05 Sep 14 @ 2:10 am
Do you have ETA when you will be updating this skin roughly? Thanks
geposted Sun 07 Sep 14 @ 12:08 pm
Inquisitiveness...
I'm kinda use to when using v7 or even v8 with utility set to other software. Not really an issue in anyway.
geposted Sat 13 Sep 14 @ 1:00 pm
