Topic: Folder,Scroll Slider issue?
Hi Fellow D jays, is there anyway to stop VDJ8 from automatically selecting the 1st track in each folder as you scroll through them?, as it is at the moment VDJ8 uses the 1st track as a starting point when you click (for example) the bpm bar the automatically selected track (highlighted in grey) is either dragged up or down the main browser window as if its being used as the focal point of the search, then I have to grab the up/down slider thing on the right hand side of the browser to scroll back up to the top. VDJ7 doesn't select any track while you go scrolling through the folders until you actually select a track by clicking on it. Hope you know what I mean
geposted Thu 24 Jul 14 @ 8:19 am
