Forum: Old versions
Topic: Playlist/Automix song should disappear when loaded
Hi, I've already searched the Forum, found some similar issues, but maybe I'm just blind... hope you can help. In VDJ7 Playlist the song automatically disappeared from the playlist when loaded into the Player. Where is this feature in VDJ8? I don't mean disappearing after the song is played (which doesn't work very well and is confusing when you want to load 2 Songs in a short time).
Every help is highly appreciated, I'll be using VDJ7 until there's a solution...
Thank you, best regards,
Sven
geposted Fri 25 Jul 14 @ 6:05 am
Just search in the options for
automixAutoRemovePlayed -> Die Option entfernt gespielte Titel automatisch aus der Playliste.
removePlayedFromSidelist -> Entfernt Titel aus der Sideliste, wenn diese gespielt wurden. (wartet "HistoryDelay" Sekunden)
(If you don't find these settings make sure you check the "advanced settings" box)
