Topic: DJ-Tech Dragon Two Bug
V8; DJ-Tech Dragon Two - When both decks are playing, and also quickly scratching either one of the platters forward and back, the GUI for the manipulated platter will freeze and loose sync.
Once I stop moving the platter the GUI will catch up and then play normally. This issue will also occur if I quickly spin one of the platters forwards or backwards.
If only one deck is playing then there is no issue quickly moving the platters.
No problems like this using V7.4 for this unit.
Scratch latency is also pretty slow. What would be a good V8 latency to set for this unit?
Thanks in advance.
geposted Fri 25 Jul 14 @ 9:44 am
Bump
Just wanted to know the the Dev team was aware of this...
Are you able to test with a different controller ? Is this an issue with the particular one only ?
We took a look at the files and didnt see anything wrong with them.
What is the Latency value you have chosen ?
What are your computer's specs ?
Ok, I the found problem.
As V8 recommends, I had to change the sample rate to 44.1k (from 48k default) since I mainly play MP3's. Now the Dragon Two and VDJ are sampling at the same rate. Runs great now. Thanks for your help DJ Dad.
Clay
