i just notice that the vdj8 doesn't sync well songs
the red/blue little cube need to be more closed to the attack pick i need all the time to fix the beatmix and to( + & - the band pitch) to correct the mix .
in the vdj7.4 for example i was not need to fix with the band pitch the mix .
this is the result take a look
vdj 8
vdj 7
what to you thinks?
vdj 8
vdj 7
what to you thinks?
geposted Fri 25 Jul 14 @ 9:09 pm
In V7 the marker for the downbeat was positioned from the centre in V8 the marker is positioned to the left edge.
geposted Fri 25 Jul 14 @ 9:55 pm
Ah, but in his pic the CBG blob is not to the left or in the centre. It's to the right. :-)
By the way, a nice list of dodgy looking web site URLs in the browser there.....
geposted Sat 26 Jul 14 @ 5:57 am
Left edge of the marker, hence to the right of the peak
geposted Sat 26 Jul 14 @ 7:54 am
looks like the grid on your track needs to be fine tuned .... i Have to adjust almost every track and i must say get used to it cause some of my tracks i have to do more then once to get it to stick and some never do :-)
geposted Sat 26 Jul 14 @ 9:50 am
I think it's another algorithm system.
I must to say that many song that synchronize well on the 7.4 vdj . Not sitting together well in the vdj8 . All the time you need to band pitch + or - . The cubes in sync mode look perfect together on the mix, But you got off beat mix , as you see in the pics above the cube position are different. Vdj8 vs vdj7.
Do you thinks that Maybe the team development may fix this problem? Or its stay like this.?
Someone have the same problem? !
geposted Sat 26 Jul 14 @ 5:36 pm
I wish they do the same sync like vdj 7.
geposted Sun 27 Jul 14 @ 4:26 pm
This is a big issue for me too! I am constantly adjusting to make songs sync. Never had this problem with VDJ7
I hope someone addresses this for us. Thank You.
geposted Fri 01 Aug 14 @ 6:19 am
Same for me. I used to be able to mix without headphones in vdj7, the sync was reliable like 95% of the time, then if it wasn't, you could see in the waves above
but now in vdj8 I *always* have to nudge it in. The BPM match is all good, but it won't lock beats. Thing is, the waves above *look* like they've found the beats, and the 4s, as well as vdj7, but in the mix I have to nudge them sometimes the waves above look a half beat off to get it clean in the output.
Weird thing is it worked perfectly once. As in load track, wait for it to load, press sync, locked. Just like vdj7. But just that once, I have no idea why.
Now I have no problem cueing on headphones, but half the point of the sync is that I'm free to throw in track after track, to run 4 decks, whatever. That's not practical for me live with vdj8 now :(
geposted Thu 27 Aug 15 @ 4:18 pm
I would like to report that the syncing in the Mac version has been horrible. It's giving delay starting and some options I can not save...
geposted Thu 27 Aug 15 @ 7:50 pm
Bizarrely, it worked as cleanly as vdj8 today, headphones unnecessary. Is this maybe a CPU thing? Or should I update the latency or priority or something?
geposted Sat 29 Aug 15 @ 8:58 pm
I got a quad core Mac with 16GB of RAM. It shouldn't even touch any CPU usage...
geposted Sun 30 Aug 15 @ 1:20 am
With build 2425?
geposted Sun 30 Aug 15 @ 7:26 am
adion ive seen it too with the latest beta
geposted Sun 30 Aug 15 @ 10:54 am
I meant as cleanly as vdj7 above ^^
geposted Mon 31 Aug 15 @ 5:15 am
Should be fixed in build 2435
geposted Mon 31 Aug 15 @ 6:30 am
Looking good to me :)
geposted Fri 04 Sep 15 @ 7:09 pm
