Topic: CPU use when is video activated
It's only a question, I was testing 4K video playing, I have discover when video is activated playing a video 4K use 01.6% processor, while is only audio use 02.1%.
There is a reason for this? when only audio module, audio have a better processing instead video plus audio is playing?.
geposted Sun 27 Jul 14 @ 12:52 pm
CPU usage is a complicated thing to measure these days, so it's basically only to be used as a guide to see if it doesn't reach too high values which could lead to degraded performance.
The reason you might see lower cpu usage while playing video, is that while playing video, the cpu has to do more work, and thus switches to a higher frequency.
Without video, it may have enough power even at the lowest frequency.
So suppose the cpu is at 1Ghz, it uses 2.1% of the time for audio, but when the cpu increases frequency to 1.5Ghz, it would only need 1.6% of the time for audio, actually doing the same amount of work.
I see, good point, speed processor nowadays are variables, switching performance according to usage.
I was thinking maybe there was missing internal functions running with video instead audio not. but was wrong :).
Thanks.
Indeed, audio quality/functionality remains the same whether you use video or not.
