Topic: Video Effect Bugs
Slideshow Effect Bug
The picture slideshow works great but when you click select (folder or picture) in the settings, none of the compatible images show in the browser. It doesn't show anything so you have to run the slideshow to see which image formats are actually working.
Text Effect Bug
The text does not resize to the screen and cuts off the typed wording. I think this should be auto resizing or allow the user to adjust the size manually.
VideoAudioOnlyVisualisation
The option to choose a Sonique Effect to play when playing an audio file.
Running...
Windows 7 on an HP Probook with Intel Core i5 processor.
geposted Mon 28 Jul 14 @ 10:26 am
Place sonique visualisations in the Documents\VirtualDJ\Plugins\Visualisations folder.
Sonique is Dead, long live Milkdrop..... it's the dogs bollocks!
Much better for your shows than the old Soniques.
Thanks
Thanks
