Forum: Old versions
Topic: Advanced audio config won't start on vdj 7.4.1 pro
Hi,
when i try to launch advanced audio configuration, nothing happens and have to force closing vdj process.
To setup the advanced audio i have to do it straight from the windows registry.
Anybody else with the same problem?
The problem is on my desktop pc, win 7 32 bit, some asio audio card(stanton scs 1.m, xite-1, hercules dj console mk2).
With the same audio cards it works on my laptop with same operating system.
Thanks for help.
SAL
geposted Mon 28 Jul 14 @ 11:31 am
i've found that the problem is with the scope asio driver.
It only works if i use the pre-made presets with 2 timecode inputs, but it hangs if advanced configuration is started.
