can u make a new plug in inthe vdj
i need it to be like total break then it will became back to normal like U or V
1. the sound is from high to low
2. there is no sound at all
3. the sound returns to it's normal postion
i hop that u can do it in a good way
thankx
thankx
geposted Sat 27 Sep 03 @ 9:51 pm
Why don't you do it with the volume sliders?
geposted Sun 28 Sep 03 @ 8:17 am
becuase it will not be like a effect
i need it to be just like the break
effect but i need it to be with an
unbreak effect
did u know what do i mean
unbreak effect
geposted Sun 28 Sep 03 @ 10:23 pm
Oug, I understand what you'r saying now. You wand it to slow down to 0 and than back to normal speed. That's cool.
geposted Mon 29 Sep 03 @ 8:18 am
i know but if ant one plz make it so it can be easy to use it will be more and more better
geposted Tue 30 Sep 03 @ 9:21 pm
You're not the first to ask for this.
I will try to do it soon... but I'm allready working on another plug_in so I don't know when will I start to work on your "unbrake" effect.
So... just wait a little :)
geposted Tue 30 Sep 03 @ 9:47 pm
ok thank u but iff u plz can u do it befor 1-1-2004
geposted Wed 01 Oct 03 @ 9:53 pm
Why? You want to make a cool New Year's party? :)
geposted Thu 02 Oct 03 @ 7:17 am
it "may" be possible yes :)
geposted Thu 02 Oct 03 @ 8:47 am
ya it is becuase i need to make a very big party in the new year and thank u guys
i need this plug in because it will be tooo great
geposted Thu 02 Oct 03 @ 9:16 pm
yeh that would be a fat plugin
geposted Thu 09 Oct 03 @ 6:24 am
hi
how r u guys so can u plz tell me what happend with u from the plug in
thanx co0ldj
thanx co0ldj
geposted Fri 17 Oct 03 @ 7:55 pm
Sorry, I don't understand what are you asking for?
geposted Sat 18 Oct 03 @ 9:02 am
iam asking u about the plug in U
r u working on it or not?
when r u going to finish it?
thanks
thanks
geposted Tue 21 Oct 03 @ 8:10 pm
Did you tried my TurnTable Start effect? With a brake effect you can stop the song and restart it with my TurnTable Start effect.
Isn't it what you are looking for?
If not, I misunderstood your needs.
geposted Tue 21 Oct 03 @ 8:58 pm
ya that it is
when iam playing a song i use the (back spin effect)and then i do the (TurnTable Start effect)and that is too coo0l
but if u plz can u make an effect that is a combination of this 2
geposted Fri 24 Oct 03 @ 6:49 pm
