What is the exact build number that you see at the top of the Settings window ?
If the unit is detected as a different one, then maybe its flashed with an incorrect firmware.
Please do the following and provide the requested data..
- Open VirtualDJ 8 and goto Settings-->Options tab.
- Set the createMidiLog setting to Yes.
- close VirtualDJ
- Make sure the G4V is connected to USB and powered on.
- Open VirtualDJ 8, let it run idle for just a few seconds and then close again.
- Upload the LogReport.txt file that you will find in Documents/VirtualDJ folder and provide the link here (or post its content here).
- close VirtualDJ
geposted Tue 09 Feb 16 @ 8:54 am
I have a gemini g4v I'm using virtual dj 8 and sometimes when I'm scratching virtual dj and the controller will freeze I have to power off the controller and restart virtual dj
geposted Fri 24 Jun 16 @ 1:04 am
Are you using some custom mapping ? If so, can you try choosing the "factory default" mapping for the G4V from VirtualDJ Settings->Controllers tab
geposted Fri 24 Jun 16 @ 9:57 am
Hi all! I recently purchased one of these gemini g4v on weekend and i still cant figure out how to make it work! i need some help please
i already updated to the latest vdj 7 le and also updated the gemini firmware.
first vdj 7 le and as well as vdj 8 recognize the g4v as g2v. even after i've downloaded the HID and MIDI files and placed them in the devices folder and the mapper under mappers, vdj 7 le and vdj 8 only shows g2v
Thanks in advance guys! i appreciate it!
geposted Tue 06 Dec 16 @ 5:22 pm
Can you take a midilog and send it to us ?
1) Open VirtualDj 8
2) Open Settings
3) Click Options
4) Search for "midilog"
5) Enable the "createMidilog" option (set it to yes)
6) Restart VirtualDj
7) Go on "Documents\VirtualDj" folder
8) Find a file named "Log Report.txt" and send it over or copy/paste it's contents here
Thank you
1) Open VirtualDj 8
2) Open Settings
3) Click Options
Thank you
geposted Thu 08 Dec 16 @ 8:22 am
Hi! here's the log report:
and thanks in advance!
--- 2016/12/09 - 20:40 (3343)
Audio device found: name="G2V Audio" vid="0x23C7" pid="0x0466" hardwareID:"{0.0.0.00000000}.{2dc77918-d383-4c37-ab63-86e8c81a5591}"
Audio device found: name="Realtek High Definition Audio" vid="0x10EC" pid="0x0888" hardwareID:"{0.0.0.00000000}.{e2299972-d3dd-4519-9a90-928083b7e945}"
Audio device found: name="dynadock Audio" vid="0x17E9" pid="0x4305" mid="0x0002" hardwareID:"{0.0.0.00000000}.{fa68b749-07bc-4a99-a513-2237653be15c}"
Audio device found: input name="Realtek High Definition Audio" vid="0x10EC" pid="0x0888" hardwareID:"{0.0.1.00000000}.{cfa6e2af-ac18-48a7-971a-7ecb6ee74419}"
Audio device found: asio="Gemini ASIO" hardwareID:"996CBA61-DA67-4D04-A5812D3409E41461"
Midi out device detected, name:Microsoft GS Wavetable Synth mid:1 pid:27
MIDI Device Identifying: \\?\usb#vid_23c7&pid_0466&mi_02#6&ff2e81&0&0002#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global (in:0 out:1)
MIDI Device Identified by PID/VID: \\?\usb#vid_23c7&pid_0466&mi_02#6&ff2e81&0&0002#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global : Gemini G2V
[20:40] Midi In Closed (\\?\usb#vid_23c7&pid_0466&mi_02#6&ff2e81&0&0002#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global)
[20:13] Midi Out Closed (\\?\usb#vid_23c7&pid_0466&mi_02#6&ff2e81&0&0002#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global)
MIDI Device Identifying: Microsoft GS Wavetable Synth (in:-1 out:0)
MIDI Device Not Identified: Microsoft GS Wavetable Synth
HID Device found: VID:0x413C PID:0x2002 path:\\?\hid#vid_413c&pid_2002&mi_01&col01#8&82f0700&1&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
HID Device found: VID:0x413C PID:0x2002 path:\\?\hid#vid_413c&pid_2002&mi_01&col02#8&82f0700&1&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}
HID Device found: VID:0x045E PID:0x006D path:\\?\hid#irdevicev2&col01#2&2818a073&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
HID Device found: VID:0x413C PID:0x2002 path:\\?\hid#vid_413c&pid_2002&mi_01&col03#8&82f0700&1&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}
HID Device found: VID:0x045E PID:0x006D path:\\?\hid#irdevicev2&col02#2&2818a073&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}
HID Device found: VID:0x045E PID:0x006D path:\\?\hid#irdevicev2&col03#2&2818a073&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}
HID Device found: VID:0x045E PID:0x006D path:\\?\hid#irdevicev2&col04#2&2818a073&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}
HID Device found: VID:0x23C7 PID:0x0466 path:\\?\hid#vid_23c7&pid_0466&mi_04#7&175bb2cc&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
geposted Fri 09 Dec 16 @ 9:41 am
All these lines indicate that a G2V is connected. It's like your G4V is flashed with incorrect firmware.
The correct PID for the G4V is pid=0x0465
I would advise you to contact Gemini and for a way to flash the G4V with the correct firmware.
geposted Fri 09 Dec 16 @ 3:14 pm
Hi djdad!
Sorry I didn't give an update til now.. I pretty much ended up just exchanging it for one that is actually a G4V.. the guys at djcity couldn't believe it when it appeared as G2V because all Gemini could tell me when they feel like replying is to uninstall-install-update.. not sure why they just kept telling me to do that when it doesn't even look like they're updating the files.. but I really like this controller.. there's sooo many buttons and knobs!
Anyway, thanks Djdad!!
geposted Sat 17 Dec 16 @ 1:42 pm
I have the same issue as Motobot - my G4v shows up as G2V. Happens in the initial firmware update.
Does anyone have a solution for this yet?
geposted Tue 27 Dec 16 @ 8:20 am
It's not a VDJ issue/problem. Read the message above yours.
You'll need to contact Gemini or the place where you bought the G4V.
geposted Tue 27 Dec 16 @ 8:54 am
HELP
i recently picked up my G4V and it was working fine. after about 10 minutes of use VDJ 8 crashed. i reloaded it and when i did non of the LED lights on my deck worked! all the butons and everything still works fine besides no lighting and the right hand sampler volume.
geposted Tue 02 May 17 @ 2:59 am
Weird issue. G4v won't scratch at all while in play but when it's paused it will. It used to work until I downloaded a few sample packs. Any ideas?
geposted Mon 14 Aug 17 @ 4:01 am
try turning on vinyl mode the button is near the platter
geposted Mon 14 Aug 17 @ 9:15 am
Hopefully someone can help me, I have a party in a couple of weeks
My Gemini G4V is not being recognized by my computer, it shows up as "Rom Recovery"
I have VDJ pro and I've had the controller for over a year.
geposted Tue 10 Oct 17 @ 10:11 pm
Probably something went wrong during a firmware update, or at any case, the unit cant recover/read the firmware. You will need to contact with Gemini Support.
geposted Wed 11 Oct 17 @ 10:31 am
Hello friends somebody can send me the Device file xml for gemini G4V and G2V i will apressiate ....I am trying to chang some functions like Master Volume but not add and midi mapping ...Hope can help me thanks
geposted Tue 17 Mar 20 @ 10:26 pm
Not entirely sure what you meant, i guess you could just change things in the mapper (without changing definition file)
But you can always install from here :
https://www.virtualdj.com/addons/16313/Gemini_G4V.html
https://www.virtualdj.com/addons/16312/Gemini_G2V.html
and you'll have both (although somewhat old files made for earlier VirtualDJ might still be ok though)
geposted Tue 17 Mar 20 @ 10:32 pm
