Discussion about Novation Launchpad VDJ8 mapper
geposted Wed 30 Jul 14 @ 4:17 am
Hi There!
I just installed VDJ 8 Pro (Mac) from scratch (no previous versions) and this mapper. It installed a "Novation Launchpad VDJ8 mapper.xml" file in my VirtualDJ/mappers folder, but I cannot get VDJ to recognise the Launchpad, among the controllers it lists only the keyboard and nothing else.
Could you please tell me what else do I need to install to get my Launchpad detected by VDJ? Many thanks.
geposted Sat 13 Dec 14 @ 5:26 pm
i have the same problem on windows 8.1 :)
geposted Fri 13 Mar 15 @ 3:29 pm
I have a solution
geposted Fri 15 Jan 21 @ 3:59 am
And that solution is?
geposted Thu 13 May 21 @ 3:32 pm
I solved the crazy frustrating launchpad no recognize Bulls#$%.. works for original launchpad pro for sure not positive on all mks but. Hold the setup button and power off and on. Keep holding setup while you do this - select the upperleft most orange square. - 2 rows of em at the top. when you do it should spell out ID 1 and leave that square highlighted. easy right? duh i wasted weeks not using that damn thingleggo of setup and turn on/off/on - should work
geposted Sat 11 Sep 21 @ 10:35 pm
