Forum: VirtualDJ Skins
Topic: Bad english
FruitPRO InfinityMember since 2003
Hello I thought about this thread to help non-english people to ask some questions about translating.
So first question is :
Let's say I have a filter to dim brightness. This filter would have two strengths.
I would like to call the heaviest one "strong".
What would the other call then ? "Weak" ??
geposted Wed 30 Jul 14 @ 9:31 am
Brightness of what? The skin colour (so a visual thing) or the sound (an audible thing)?
If it's brightness of the skin, I would suggest 'bright' and 'dim' or 'dull'.
geposted Wed 30 Jul 14 @ 9:36 am
If the highest setting is 'Strong' then the lowest setting would be 'weak' or you cold use 'mild'
but you yourself used,
heaviest > lightest
here might help http://www.synonym.com/antonyms/strong/
geposted Wed 30 Jul 14 @ 9:49 am
locodog wrote :
you could use 'mild'
Oh yeah !
mild : doux (soft, sweet, mild, gentle, smooth, tender)
That seems to be my answer ! Btw it is for dimming some images, not sound. Also that's not to describe high and low values (+ / -), but two steps of a lowering filter (- / --).
So, mild / strong seems to be a convenient couple ?
geposted Wed 30 Jul 14 @ 10:08 am
Works for cheese, don't see why it wouldn't work for fruit!
geposted Wed 30 Jul 14 @ 10:18 am
"Subtle" could also work.
geposted Wed 30 Jul 14 @ 10:21 am
Subtle / Strong ? would fit together ?
Not bad at all. Still thinking about mild, or maybe 'soft' which I didn't remember first.
geposted Wed 30 Jul 14 @ 11:08 am
1) "Every vu-meter is..."
Or
2) "Every vu-meters are..."
geposted Thu 31 Jul 14 @ 5:48 am
1
or
All vu-meters are
geposted Thu 31 Jul 14 @ 6:20 am
Thx ! :)
geposted Thu 31 Jul 14 @ 6:54 am
