Discussion about Denon DN-MC6000 Enhanced Mapper
MAPPER: DN-MC6000 Enhanced (3-1L-R2-4) Controller Mapper v8.2
Description:
DN-MC6000 Enhanced Controller Mapper v8.2
Enhanced Controller Mapper for the DN-MC6000. VirtualDJ v8 supports (3-1L | R2-4) and (1-2L | R3-4) mixer configurations. This mapper is designed to work with the native DN-MC6000 definition file.
Mapper function control layout:
Section: FX Panels
It has 4 modes each which can be cycled through using the SHIFT + FX2 button on each deck:
- Mode 1, FX2 Led OFF, FX panel (default/factory panel):
- FX Knob 1: Effect Select knob
- FX Knob 2: Effect Parameter 1 knob; w/SHIFT: Parameter 3 knob
- FX Knob 3: Effect Parameter 2 knob; w/SHIFT: Parameter 4 knob
- FX Knob 4: Filter knob; w/SHIFT: Default Sampler Volume
- EFX.1 Btn: Effect Active button
- EFX.2 Btn: Effect Parameter 1 button; w/SHIFT: Parameter 3 button
- EFX.3 Btn: Effect Parameter 2 button; w/SHIFT: Parameter 4 button
- EFX.4 Btn: Filter Active; w/SHIFT: Default Sampler Play/Stop
- Mode 2, FX2 Led BLINK, SAMPLER panel:
- FX Knob 1: Sampler Select knob
- FX Knob 2: Sampler Bank knob
- FX Knob 3: Sampler Volume
- FX Knob 4: Filter knob; w/SHIFT: Musical Key knob
- EFX.1 Btn: Sampler Play/Stop; w/SHIFT: Sampler Play/Stutter
- EFX.2 Btn: (unassigned)
- EFX.3 Btn: Sampler Volume 100%
- EFX.4 Btn: Filter Active; w/SHIFT: Key Reset
- Mode 3, FX2 Led BLINKFAST, LOOP ROLL panel:
- FX Knob 1: (unassigned)
- FX Knob 2: (unassigned)
- FX Knob 3: (unassigned)
- EFX.1 Btn: Loop Roll 1/8th beat; w/SHIFT: Loop Roll 1/8th beat while pressed
- EFX.2 Btn: Loop Roll 1/4th beat; w/SHIFT: Loop Roll 1/4th beat while pressed
- EFX.3 Btn: Loop Roll 1/2th beat; w/SHIFT: Loop Roll 1/2th beat while pressed
- EFX.4 Btn: Loop Roll 1 beat; w/SHIFT: Loop Roll 1 beat while pressed
- Mode 4, FX2 Led ON, BEAT SLICE panel:
- EFX.1 Btn: Slice 1:4
- EFX.2 Btn: Slice 2:4
- EFX.3 Btn: Slice 3:4
- EFX.4 Btn: Slice 4:4
Section: FX1/FX2 (FX buttons by the DECK CHG. button)
- FX1: Fire Flanger effect; w/SHIFT: Toggle SLIP_MODE (besides FX1 being lit up, all 4 EFX buttons will BLINK while SLIP MODE is active and the FX Panel in mode 1)
- FX2: Fire BeatGrid effect; w/SHIFT: Cycle through the FX Panel 4 modes (LED indicators: Mode 1 (default): OFF, Mode 2: BLINK, Mode 3: BLINKFAST, Mode 4: ON)
Section: Track selection
- "TRACK SEL." (knob) - will scroll through the items on the active panel (songs/samples); w/SHIFT: scroll through the folders.
- "TRACK SEL." (push) - When focus is on the "songs" window it will trigger the BROWSER ZOOM function on selected skins; w/SHIFT: open/close folders. When on SAMPLER sideview, play/stop sampler.
- "BACK"/"FWD" - Will cycle throughout all available sideview panels.
Section: Panel selection
- "BROWSE" - Will return you back to the file browser, each successive press will cycle the cursor focus on all visible panels.
- "SAMPLE" - Will open the SAMPLER sideview and shift cursor control to it, successive presses will change the Sampler Banks. To return to the file browser press "BROWSE" or close the Sampler sideview
- "EFX" - Will open the Effects sideview, press again to close.
- "RECORD" - Will open the file record window.
Section: Loop Controls
- "Shift + LOOP IN" - Reloop your last active loop.
- "Shift + LOOP OUT" - Toggle v8 Loop Roll mode
Section: Mixer Controls
- When activating a channel's PFL it also makes it the active deck.
- "Shift + Ch(x) PFL CUE" - This will UNLOAD the specific deck.
Section: Deck Transport Controls
- "Shift + CUE (hold for .5 seconds & release)" - Toggle PROTECTED CUE mode (see additional info below)
- "Shift + PLAY (hold for .5 seconds & release)" - "Go to track's 1st beat and pause deck"
- "Shift + CUE" - Toggles SMART CUE ON/OFF (while pressing SHIFT on the controller the CUE button indicator will FASTBLINK when smart_cue is ON)
- "Shift + PLAY" - Toggles SMART PLAY ON/OFF (while pressing SHIFT on the controller the PLAY/PAUSE button indicator will FASTBLINK when smart_play is ON)
- "Shift + PITCH BEND -" - Move CBG marker in steps of 2%
- "Shift + PITCH BEND +" - Move CBG marker in steps of 1 beat
Section: All other sections
- The rest of the buttons and sliders follow their factory configuration.
Additional Mapper features:
- Fully supports DJ Lunatico's DN-MC6000 Pro v8 Skin set.
- Synchronized transport control lighting with the use of matching Skin sets.
Protected Cue:
Normally the CUE can be overwritten with the CUE button when the deck is paused, when "Protected Cue" is active, pressing CUE while the deck is paused will take you back to the pre-existing CUE rather than setting a new one. With this mapper, when the Deck is paused, the CUE light will BLINK when the CUE is overwritable (just like the Pioneer units) and remain OFF when you cannot set a new CUE (protected).
Additional notes:
- Matched skins are available in the SKINS section:
http://www.virtualdj.com/addons/16825/DN-MC6000_Pro__v8.html
- Some functions are activated by using a combination of buttons on the controller. When using SHIFT in your sequence make sure you press SHIFT FIRST and release LAST. There is a bug in VDJ where if you release SHIFT while still holding your secondary button and do this enough times VDJ will stop communicating with the controller until you restart VDJ.
- Other functions require you to hold the secondary button for a specific amount of time in order for a particular feature to be activated. Note that triggering occurs at the release of the button. Not waiting the amount of time required will trigger the other function that did not require the holding time.
- You may need to re-adjust your starting volumes for the SAMPLES playback
Instructions:
*** IMPORTANT***: Since VDJ8 supports multiple mappers for a given controller, make sure you select the correct mapper for the DN-MC6000 otherwise you might get unexpected controller behaviour.
Just download the XML file and put it in the MAPPERS folder of Virtual DJ.
*** Revision history ***
Version 8.2 changes:
- "BACK" / "FWD" - Will cycle throughout all available sideview panels.
- Use BROWSE to return focus to file/folder windows
- Added functions to move CBG marker in different steps
- Added funtion to toggle v8 Loop Roll mode
Version 8.1 changes:
- Corrected some name changes on the effects so that they trigger correctly
- Added BROWSER ZOOM function to the TRACK SEL. push button, usuable with the DN-MC6000 Pro+ v8 skin and most of DJDAD's v8 skins
- MIXER/VIDEO/SCRATCH buttons now linked to the DN-MC6000 Pro+ v8 skin
- CF MODE button now linked to the DN-MC6000 Pro+ v8 skin
- Cleaned up the functions on the Browse/Sample/EFX/Record buttons
Version 8.0 changes:
- For VirtualDJ v8.x, this version is not compatible with VDJ7.x
Version 1.6 changes:
- Incorporated VDJ's native SLIP_MODE and LOOP_ROLL functions
- Defined a small 4-Pad area in the FX Panel sections to trigger effects
- Added Sampler panel and Musical Key control knob & Key reset button
- Added 4 predefined Loop Roll effects
- Added 4 predefined Beat Slice effects
Version 1.5 changes:
- "Shift + EFX.1" - Toggle SLIP mode for specific deck (this function has been deprecated)
- "Shift + PLAY (hold for .5 seconds & release)" - "Go to track's 1st beat"
- Synchronized transport control lighting with the matching Skin Set.
Version 1.4 changes:
- Incorporated minor mapper revisions made on the DN-MC6000's Controller Definition File as of v7.3
Version 1.3 changes:
- Added support for DJ Lunatico's DN-MC6000 Pro Skin set
Version 1.2 changes:
- Works with DN-MC6000 Enhanced v1.1 Skin Set
Version 1.1 changes:
- XML controller Mapper file and the SKINS (available separately) now match the Channel order of (3-1L | R2-4)
- Master Volume is mapped to Virtual DJ.
- PFL/Headphone CUE/Deck Select now works correctly. There was an issue where you could not make a particular deck active or the wrong channel would be sent to the Headphone Cue.
Description:
Section: FX Panels
Protected Cue:
Additional notes:
Instructions:
geposted Thu 31 Jul 14 @ 7:27 pm
que tal mi estimado, me podrias porfavor ayudar con un link para descargar este mapper, te l agradeceria muchisimo...gracias
si no es molestia este es mi *************
Los usuarios domesticos no pueden publicar informacion de contacto
geposted Sat 21 Oct 17 @ 10:41 pm
