hi
im using a pioneer DDJ_SR and build 1897-751
problem with pitchlock
every time i close and reopen vdj i have to go back into options and change,
pitchlock back to yes,
for some reason it never saves it
aubs
aubs
geposted Fri 01 Aug 14 @ 3:57 pm
Yes, it resets on launch, like may other settings. If you need the pitchlock to be enabled on launch, add the action to the ONINIT of your keyboard.
geposted Sat 02 Aug 14 @ 9:52 am
I too am having this happen, pitchlock is reverting to NO when I load songs. Why have a "yes" option if it won't save? How can this be fixed?
geposted Sun 21 Feb 16 @ 8:41 pm
It doesn't need "fixing" because it's not broken. It's working as intended.
However, if you need it to be permanently on, the answer was provided in the post above yours.
By the way, please don't post the same question in different areas. Once is enough.
geposted Sun 21 Feb 16 @ 8:51 pm
