Forum: Old versions
Topic: cdj-800 MK2 timecode hardware setup
Hi guys,
Normally I use a maya44 & my 1200's but on monday I'll be doing a home session at a friends place with cdj's
Now I have a (stupid) question :)
I'm wondering how I should hook up the cdj's to use timecode cd's in vdj 8.
I'll be using my rane TTM56 as mixer.
Do I need to wire it the same way as I wire my turntables?
I also saw it has an usb slot to load tracks from a stick, do I need to connect the cdj's via usb to the laptop & run the outputs to my maya?
I'm also guessing I will need the 'Pro Grade Sound Level' timecode cd's instead of the other ones?
Any help would be highly appreciated as I won't have hours to waste fixing the setup at that location, as monday & the day after is a working day for most people
Das
geposted Sat 02 Aug 14 @ 5:29 am
