Forum: Old versions
Topic: Scratching wit the DDJ SR
Is anyone else having trouble scratching with DDJ SR?
When I use serato it scratches fine, but with VDJ 8 there is like a delay when I let go of the platter.
geposted Sat 02 Aug 14 @ 6:04 pm
The software by default waits until the platter completely stops spinning (back) before continuing again.
You can try the setting .. TouchWheelBackspin to No, or you can adjust your scratching techniques to push the wheel a bit forward before releasing that.
Does the DDJ-SX have the same problem?
If you consider this as a "problem", then every single midi controller has that :)
