Forum: VirtualDJ Skins
Topic: Hercules MP3 LE
BillbwePRO InfinityMember since 2011
Can anyone let me know if MP3 LE will ever have a skin (map) in Version 8 ?
geposted Tue 05 Aug 14 @ 1:28 pm
Is there some functionality of the Hercules MP3 that you miss from the default skin ?
Btw, do you mean the old Hercules Control MP3 or the newer MP3 E2 ?
geposted Tue 05 Aug 14 @ 7:16 pm
I mean the old one, and it appears that no matter what I do I cannot get it to work. Do I have to map it myself or should it already be done ?.Remember not all of us are really good on the PC, lol.
Thanks for replying.
geposted Wed 06 Aug 14 @ 1:19 am
So you are saying that the controller is not working ?
It happens to have the controller here and last time i checked it worked fine.
So, it appears that your issue is not related to the Skins, if the controller is not functional. But anyways, i wont move that to a different Forum to help you get a solution.
Please do the following...
goto VirtualDJ/Devices folder and delete the controllers.dat file you will find in there.
Launch version 8, leave it idle for about 5 mins, and then launch again.
Make sure your build ends at .763 (or higher). If not, wait for a few minutes more and then relaunch.
Goto the controllers tab and select the "factory default" mapping from the list (if its not selected already)
If the unit is still not working properly, please do the following...
Enable the setting createMidiLog from OPTIONs (Advanced Options)
close VirtualDj, connect the Hercules, and relaunch.
Close again (no need to do anything else) and post here the content of the Log Report .txt file you will find in /VirtualDJ folder.
geposted Wed 06 Aug 14 @ 2:10 pm
All I would like is a skin that looks like and functions like a Hercules MP3 LE (old style), if that ain't possible then that's cool.
geposted Thu 07 Aug 14 @ 4:01 pm
