Forum: Addons
Topic: NI Kontrol X1
pOpYDJPRO InfinityMember since 2006
Discussion about NI Kontrol X1
!! VirtualDJ.ncc file is inside the ZIP Download !!
Definition/Mapper Version: v1.2
First of all: Thank you fgeibel, i have used your definition file and added the leds!
English:
This Mapper is for Traktor Kontrol X1 using its own device definition file.
Also the Leds are working :-)
Installation:
* Download & Install the Traktor X1 Driver from the NI Homepage
* Download & Install the Controller Editor and load/upload the configuration file "Virtual DJ.ncc"
* Set LED Off State (Dim): You could set the off state brigthness for all LEDs in the Controller Editor
ToDo so, start the controller editor goto File -> Preferences -> Controller -> Select the X1 and set the values (sliders) to your needs
Hint: To save the brightness (also after reboot) you must use a workaround (for that NI bug). Just leave the window with the silders
opened and reboot windows! Now the brightness state should be saved and loaded every time you plug in the X1 ;-)
(It looks really cool)
* Don't forget to activate midi mode on your control X1 by pressing Shift+Hotcue, the Hotcue button has to light up green
* Open/Restart VDJ and goto Setup -> Mappers - There should now be a entry "Traktor Kontrol X1"
* Now you could setup the mapper to your needs (or just use mine :-).
Deutsch:
Dieser Mapper für Traktor Kontrol X1 benutzt eine eigene definitions-datei.
Außerdem funktionieren alle LEDs :-)
Installation:
* Laden & Installieren Sie den neuesten Traktor X1 Treiber von der NI Homepage
* Laden & Installieren Sie den neuesten Controller Editor und laden Sie die KonfigurationsDatei "Virtual DJ.ncc"
* LED Auszustandshelligkeit (dimmen): Mit dem Controller Editor können Sie die Helligkeit der LEDs im Auszustand einstellen.
Starten Sie den Controller Editor und wählen im Menü File -> Preferences -> Controller -> Wählen Sie den X1 und stellen Sie alles wie gewünscht ein.
Tipp: Um die Helligkeit zu speichern (auch nach einem Neustart) müssen Sie einen kleinen NI Bug umgehen. Lassen Sie das Fenster offen und
starten Sie Windows neu. Nach dem Neustart sollten die vorher eingestellten Werte wieder geladen werden :-)
* Vergessen Sie nicht den MIDI Mode am X1 zu aktivieren, um die zu tun drücken Sie Shift+Hotcue, der Hotcue button muss grün leuchten
* Öffnen/Starten Sie VDJ und gehen Sie zu Setup -> Mappers - Dort sollte nun der Eintrag "Traktor Kontrol X1" stehen
* Nun können SIe den Mapper nach Ihren Wünschen anpassen (oder Sie benutzen einfach meinen :-)
Changelog
v1.0: initial version
v1.1: Added Potis of effect section 1/2 in SHIFT mode
v1.2: Removed X1 identification (midiname) - made problems on MAC and if more than one X1 are used in windows. There is no sysex id from the X1, hope there is another way to identify the controller soon...
Have fun
DJ pOpY
geposted Fri 08 Aug 14 @ 4:43 pm
CantalienPRO InfinityModeratorMember since 2008
This is good work.
In the zip file, there are two xml files.
I think he's one for the DEVICE and the other for Mappers file, but what?
geposted Fri 10 Oct 14 @ 3:01 am
Hey, i noticed a huge issue here. When i press the "Bend - key" on the 2nd unit it does not stop bending when i unpress it. When i press "Bend +" it disengages. Can you fix it and update it for us. Thanks!
geposted Fri 28 Nov 14 @ 12:20 pm
LeharaPRO InfinityMember since 2017
WHERE IS THE ZIP FILE WITH THE NCC FILE?? ALL I GET IS AN EXE THAT DOIESNT WORK
geposted Fri 11 Mar 22 @ 6:24 am
Run the EXE and install the zip file to VirtualDJ directory.
This mapper is very old, almost 10 years old. But I tried it just for fun here, and it shows up fine
(i dont have the controller to test the mapper, but probably works fine)
geposted Fri 11 Mar 22 @ 7:45 am
And read the instructions in the first post about how to make it work
rgrrbtPRO InfinityMember since 2023
I realize this is an old mapping, but I would like to look at the coding to see how the LED integration was accomplished. The original link to the mapping no longer appears to be valid for the Addon database, and searching the database has not resulted in success. If someone can provide a copy of this mapping, I would greatly appreciate it. Thank you.
geposted Sat 04 Nov 23 @ 4:45 pm
pretty sure this requires a pro license
you appear to be a home user
geposted Sat 04 Nov 23 @ 5:30 pm
I've purchased a pro infinity license. Can anyone provide the Virtual DJ.ncc file referenced above? It does not appear to be in the Add-On database.
geposted Sat 11 Nov 23 @ 5:12 pm
If anyone has access to this custom definition file for the Kontrol X1 Mk1, please upload it in the addons section or post here in this thread. VDJ's native support definition file has two of the endless encoders that send distinct CC values defined as a single key. In addition, the native definition file in VDJ is missing several of the LED keys. In order to complete my custom midi mapping objective, I need a custom definition file for this controller. I would rather not recreate a definition file if someone could share this custom file.
geposted Sun 12 Nov 23 @ 7:57 pm
You might want to try asking on the Native Instruments forum, as it's one of their products. I guess there aren't many here that use it, so you might have more luck there.
geposted Sun 12 Nov 23 @ 8:16 pm
Thank you for the response. I'll try over there. I just thought someone might still have a copy of the definition file that was originally posted in this thread. Just trying to avoid recreating the wheel.
geposted Sun 12 Nov 23 @ 8:22 pm
