Forum: Addons
Topic: Traktor Kontrol F1
Discussion about Traktor Kontrol F1
**BUTTONS ARE EXPLAINED WITH THE "TRACK DECK" OVERLAY ON THE F1**
LED only works if you install my F1 configurations for "Native Instruments: Controller Editor" which is the Documentation/Instruction file you can download (in .RAR).
v1.1 update: Fixed the browser knob
ON THE PICTURE:
1: DRY/WET Knobs = Dry/Wet (parameter 1) on FX for Deck1/2
2: Filter Knobs = Filter for Deck1/2
3: Slider 2s = Not Done
4: Slider 1s = Parameter 2 on FX for Deck1/2
5: Browser Knob = Scroll to browse tracks, Press to select map/track, Scroll while holding shift to browse in maps.
6: ReverseButton = Load A / SizeButton = Load B / Hold TypeButton + Press Reverse or Size Button = Duplicates other deck
7: Push to set or play Hot Cue / Hold Shift and press to delete hotcues (leftside=deck1 rightside = deck2)
8: FX1 Buttons = Activate Beatgrid for Deck1/2
9: FX2 Buttons = Activate Flanger for Deck1/2
Files:
Traktor Kontrol F1 MIDI Mapper.xml
Traktor Kontrol F1 MIDI.xml
Virtual DJ.ncc
**Will finish this midi-map as soon as possible**
Report a bug or a suggestion? Feel free to email me at dj@zablar.com
Have fun!!
//DJ Zablar
geposted Fri 08 Aug 14 @ 4:58 pm
Hi!
Thank you for your help. I have a query. If you can help that would be great, it's a request. I have an F1. I would like to use it as my main controller (with the functions of the X1. Like to load tracks on deck A / Deck B, browse through folders/tracks, I would like to use the faders as pitch, Play/Pause/Stop buttons etc.) Please can you help me with the same? I would really appreciate if you could help. Please do let me know.
Thanks in advance.
Regards,
DJ Bobby K.
thx
