Hi,
Just a quick note to let you know that on my current installation of Virtual DJ 8, karaoke tracks cause the software to lock up and crash when loading into either player. Build 1897.765
geposted Sat 09 Aug 14 @ 1:10 pm
think there's a fix in new build time to update
geposted Sat 09 Aug 14 @ 1:29 pm
Thanks, how do i force the update, the software doesnt ask me to update when i run it?
geposted Sat 09 Aug 14 @ 2:45 pm
The fix for the Karaoke is available at the beta build for now. Either you need to wait for that to become public (a few days i guess) or enable getBetabuilds setting from Config->Options
geposted Sat 09 Aug 14 @ 2:48 pm
Smashing, Thanks for the help, your a star!, i'll hang on as i dont need karaoke till Friday again, if no push out ill enable the beta to get it.
Thanks once again.
Thanks once again.
geposted Sat 09 Aug 14 @ 2:49 pm
