Ok I have seen several users do it but I would like to know how? Because if not then I was gonna go with my original plan and get the ns7 2, but if this is possible then i'd rather do the timecode vinyls because I really like virtual dj. Any help please?
geposted Sun 10 Aug 14 @ 7:31 pm
In order to use Timecode vinyls, you would first need to purchase VDJ Pro Infinity.
In the meantime, you could give it a try using the Home version. The audio configuration guide gives you the information necessary to the audio setup (look at Page 20):
https://virtualdj.com/images/pdf/VirtualDJ%207%20-%20Audio%20Setup%20Guide.pdf
Then you can move on to setting the Timecode vinyl:
https://virtualdj.com/wiki/TimeCode%20Config.html
geposted Mon 11 Aug 14 @ 7:02 am
