Discussion about EQ 10 Bands
geposted Sun 10 Aug 14 @ 10:28 pm
I try to apply this in my Mac but its no working,this what i did , i download and than i move this effect to effects but its no worrking , can you help me if i did something wrong........
geposted Sun 10 Aug 14 @ 10:31 pm
This is what show when I try to change ,this only happen on Mac .
geposted Sun 10 Aug 14 @ 10:48 pm
geposted Sun 10 Aug 14 @ 10:49 pm
I'm unable to replicate here. Anything in your system console?
geposted Mon 11 Aug 14 @ 7:07 am
I dont understand your question? Can you be more specific please,,,
geposted Mon 11 Aug 14 @ 9:18 pm
Does the Console application in Mac OS X log anything when you open VDJ or do anything with the effect?
geposted Tue 12 Aug 14 @ 7:27 am
No, doesnt show anything ,its only when I want to apply the effect ,show its incompatible .
geposted Tue 12 Aug 14 @ 9:22 pm
Any help for this annoying issue
geposted Sat 04 Oct 14 @ 7:40 am
Unfortunately I've been unable to replicate and no-one else has yet reported this issue either.
I will add some debug logging to see if we can see what is going wrong on your system.
You are saying it only comes up as incompatible when you try to activate the effect right - it's fine when you select it?
geposted Sun 05 Oct 14 @ 8:34 am
that corret and Idont know how solve .
geposted Mon 20 Oct 14 @ 10:34 pm
Also seems to me the same thing
geposted Wed 22 Oct 14 @ 3:13 pm
Osx 10.8.5 2,3Ghz i7
v1.1 uploaded - hopefully to fix issues for certain Mac users
geposted Wed 22 Oct 14 @ 3:52 pm
Thank you ,its working good ,both the 10,30 band ,good Job SBDJ.
geposted Fri 24 Oct 14 @ 4:47 am
Just DL this add on and dont see it anywhere Windows
vdj8
geposted Fri 27 May 16 @ 4:07 am
Did you install it?
geposted Fri 27 May 16 @ 5:16 am
locodog wrote :
Did you install it?
Yes and I see nothinhg considering thjere are no instructions it shouldn't be a chiese jigsaw puzzle
geposted Sat 28 May 16 @ 5:17 am
Instructions
Download
Install
Open from fx drop down
Might only be found in master fx section, not sure.
Download
Install
geposted Sat 28 May 16 @ 5:19 pm
locodog wrote :
Instructions
Download
Install
Download
Install
It fn the sound fx folder a sub folder of PLUGINS but doesn,t work
geposted Mon 30 May 16 @ 2:03 am
