Topic: Pitch Jumping VDJ8
Hi Guys.. This problem only started at my last gig.. When playing a track the pitch starts to jump up and down any ideas on what could be causing this to happen?
I'm using the following
iMac 22" Updated
NS7II Audio Updated
VDJ8 Updated
geposted Tue 12 Aug 14 @ 7:21 am
Confirmed.
I am having this same issue. Please Advise.
there will be an update to NS7II default mappers soon. In the meantime, assign the pitch fader as .. pitch 'dual'
@RCBAudio, do you use a NS7II too ?
Hi DJDad
Tried it.. Still the same and I just saw the pitch range jumps from my setting of 12% to 46% if that helps.
Do you have "autoPitchRange" activated?
No I do not use that Controller.
No turned it's off.
I'm after changing a few settings and doing a few tweaks. Seems to be going well.. SO FAR!!!
Going to give it a spin at tonights gig to see if that sorted it out..
Cheers for the help guys..
That was happening with me and my NS7 too. ASUS laptop. NS7. VDJ8.
I'll try the suggestions listed.
jayos what settings/tweaks did you use
