-Fix downloaded plugins name on mac
-Fix playlist filename with accents when saving from automix
-Fix click-through of custom skin menus
-ccback added for jog wheel for controllers with different cc value for forward and backward movement
-Prelisten no longer stops working when selecting a missing or broken file
-recordWaitForSound fixed
-Fix possible automix crash when playing video
-Fix playlist copy to/move to context menu options
-Fix v7 import of Virtual Folders with certain characters in the name (*,?,/,etc)
-Fix cdj900/2000 jog display glitch
-Improve use of some icons for cdj900/2000
-MP4 recording uses AAC for audio instead of mp3 (fixes playback on mac in iTunes/Quicktime)
-Don't automatically load songs on invisible decks
-Fixed artwork covers when using linein
geposted Wed 13 Aug 14 @ 6:17 pm
Update fails here.
On win 7 trying to update from 1910.766.
geposted Wed 13 Aug 14 @ 6:58 pm
Pangolin's Essential Visuals beta version 8.22 crashes VDJ8 with an unhandled exception error.
geposted Wed 13 Aug 14 @ 7:56 pm
Can't changer the setting on the skin
geposted Wed 13 Aug 14 @ 9:07 pm
^^ Same here - workaround was to download the full version.
geposted Thu 14 Aug 14 @ 12:41 am
Same here - On Mac in all skins Menues don't work. Should be fixed quick.
geposted Thu 14 Aug 14 @ 1:48 am
since build 1.955 I couldn't auto update,files always got damaged,prompted for downloading new 1.190,installed and then new build 1.918 auto updated fine, but there are still stanton scs1d platter issues when platter is held still, track moves/jumps allaround. slow drag scratches are still impossible...
I think the pitch up when turning vinyl on/off or switching between decks is getting better,try cloning decks,and switch between decks or turn vinyl on/off, I also think it works better with keylock off.
confirm drop down menu are missing on mac.
looking forward
thank you
looking forward
thank you
geposted Thu 14 Aug 14 @ 6:46 am
ash, do we need to see your 'mac about screen' just to prove youre on a mac??
people will get the hump if i start posting with my about windows 8.1 screen... lol
geposted Thu 14 Aug 14 @ 6:47 am
I think it's more to show what version of OSX people are using, however from what I have seen, it doesn't really matter. 10.8, 10.9, 10.10 (Yosemite), it's all the same for the most part for VDJ...
geposted Thu 14 Aug 14 @ 7:51 am
Sorry about that next time I will make it more easier to understand with out posting large pictures with examples.
geposted Thu 14 Aug 14 @ 9:42 am
When you cannot autoupdate it's because a process from VirtualDJ ist still running thus the program cannot update the .exe file. The problem is that this process is protected and cannot be forced closed from task manager, only possible solution... REBOOT!
If anyone has a suggestion you're welcome...
Anyway that's a bug and it must be solved in the code of the program...
geposted Thu 14 Aug 14 @ 9:43 am
ver 1918
2 problems not solved .
1. command+Q doesn't have security exit. (load security on options are = on)
2. automix side list. have stutter( bad sound) when mixing between songs.
hope will fix soon . thanks a lot.
geposted Thu 14 Aug 14 @ 10:02 am
1918-----Vestax VCI-300 mkII
The jog wheels no longer work in windows
The jog wheels don't work correctly in Mac
Fixed.. The jog wheel setting got erased from the mapping.... (it was there on 1910)
geposted Thu 14 Aug 14 @ 10:33 am
djbennybm wrote :
ver 1918
I agree with this also
geposted Thu 14 Aug 14 @ 1:42 pm
Fix autocue not cuing to the first beat or skipping the silence when settings are indicated?
geposted Thu 14 Aug 14 @ 1:56 pm
command + q does have a security exit.
It works if a song is playing.
geposted Thu 14 Aug 14 @ 2:05 pm
i am not sure if this is the skin or the build but its never happened till after this update so here goes
after expanding and contracting the options in the menu pictured here from the skin by fruit
the menu will not close
even closing vdj the menu remains open
i have to kill it in the task manager
also I should add I can duplicate this bug over and over its not a one time thing every time I repeat the above it happens.
reverted to 1910 and the menus are different (no more + and -) and the issue goes away.
kinda like it better without the + and - anyways
thanks.
thanks.
geposted Thu 14 Aug 14 @ 2:34 pm
In pervious vers 1897 its work not only if the song are played. Also in stop mode. "Are you sure you want to exit virtualdj?" Its very important for us beacuse the vdj can be exit or fall without worrying.
geposted Thu 14 Aug 14 @ 2:55 pm
Didn't know that, thanks.
I can confirm this, wow it is very annoying lol :)
Thus, Wicked, you can close the menus triggering Alt-F4. Hope this will be sorted out soon.
geposted Thu 14 Aug 14 @ 6:24 pm
Command + q, is meant to close the program, any program. If you are doing something, it will give you the warning, asking you if you are sure. This is so you don't make a mistake, which we all do, sometimes. However, if you are not doing anything, and are not playing a song, why do you need a warning? You are pressing two keys, to shut down the software. If nothing is playing, and it shuts down, what's the problem? I don't use a Mac, but am staying in a room, with someone that does, and you get a warning, if a song is playing.
geposted Thu 14 Aug 14 @ 7:00 pm
