Forum: VirtualDJ Skins
Topic: groovin dj
pseftPRO InfinityMember since 2009
geposted Tue 19 Aug 14 @ 12:19 pm
OK so you've created this image from parts found via Google & transplanted it into the top part of the PNG file in a VDJ 8 skin, replacing the graphic that was originally there?
The rest of the graphics below it are still there, yes? You've just covered over the top 1920x1080 "background" section with another 1920x1080 graphic?
If so, there shouldn't be any problem with the skin opening.
To everyone else - excuse us while we discuss this!
geposted Tue 19 Aug 14 @ 12:54 pm
does the images that iv used have to b a certain size from original templates... sorry for late reply
geposted Tue 26 Aug 14 @ 11:33 pm
i just cut out the decks and painted it with GOLD paint and still same... nothing.
i must be doing something wrong
geposted Wed 27 Aug 14 @ 12:02 am
I think it may be best if we carry on via email.
You can send me the original skin (or tell me which one you used) and also your modified one, then I can investigate.
geposted Wed 27 Aug 14 @ 5:21 am
v8 2 decks
geposted Wed 27 Aug 14 @ 6:29 am
I have corrected your yellow variation, and changed the colours of the text labels from white to black so they show against the yellow.
Shall I send it to you?
geposted Wed 27 Aug 14 @ 7:37 am
