Hello. I own VDJ 7 broadcaster edition, and use VDJ 8 with the broadcaster license recently, to broadcast to a stream where there are multiple DJs in rotation. I'm having a problem with both versions.
I've been having this problem on multiple different ShoutCast streams at different bitrates. The problem is, there is a very noticeable delay (10-30 seconds) in between disconnecting and the next DJ being able to connect to the ShoutCast stream. This is making handoffs very bothersome for me. I don't know why there is now a delay in between me clicking disconnect and my VDJ client actually being disconnected from the stream, but I'd like to fix it somehow.
Thank you.
Thank you.
geposted Wed 20 Aug 14 @ 3:04 pm
don't count on it being something you can fix due to so many variables that you have no control over but good luck and this is not a issue with the software happens to everyone if u get lucky and both people have good timing and low lag connection it might be minimized. good luck with it
geposted Fri 22 Aug 14 @ 4:48 pm
Having this problem as well, and after poking at it for awhile I'm having no luck finding the cause. Any suggestions?
geposted Sat 13 Feb 16 @ 1:47 pm
