Forum: Beta Builds Regression Bugs
Topic: BUILD 1926 - Page: 2
djcel wrote :
@Fruit
Can you give a real example of what you call "sub-menu". Tell us which menu on the skin, ...
Just every <submenu/> element... For instance, let's say, in my skin 0.5d : "deck menu / screen" or "atomix menu / topbar layout" or even every submenu of the VirtualDJ logo.
It happens also in other skins i.e. the hercules RMX 2 when trying to set cover options, or SilverSleek when entering the topbar menu.
Of course if I just open a menu, it closes perfectly, the problem is when a <submenu/> stays opened while I click away to close the menu window without choosing anything.
I tried to change the language to french but with no success. I tried to launch VDJ with a brand new settings.xml, no success... If you want me to try something, feel free to ask me :)
We can see on the second pic that several menus stayed open (about 12-14).
i have the same issue as fruit above and i can duplicate it any time i wish over and over.
with any skin that has menus with sub items.
windows 7 64 bit
Will not recognize the controller no Icon but sound.My RMX II work and shows Ok
I don't know if these bugs are regression bugs but, playlist files created with version 8 are unusable outside of VDJ8.
Time code vinyl for serato needs work, sticker drift getting worst, when a song is loaded on deck while another is playing only portions of the new song is loaded
windows 7 64 bit
+1
are you using mouse or touch, is this on a touch-screen enabled computer?
How do you open the submenu, clicking on the small arrow, or doubleclicking on the submenu text? (or with keyboard).
Does this happen if you open the submenu, but leave the selection elsewhere, or only if the selection is moved inside the submenu?
I will attempt to make a video this evening when I get home and post here unless someone beats me to it
It's ok we could finally reproduce it.
Should get it fixed quickly now.
ok fixed, expect a new build soon.
Sounds good, keep up the good work ^^
