If you ever need to download a previous build (to test a regression bug for example), you can easily do so by going to:
https://virtualdj.com/download/virtualdj8/pc/1932 for example (replace "1932" by the build number you need, and replace "pc" by "mac" if you need).
If you want to download just the executable, and not the full installer, use:
https://virtualdj.com/download/virtualdj8/pc/1932/zip
geposted Fri 22 Aug 14 @ 8:35 pm
