Topic: The Latest build 1910
couple of questions folks. How do I upload the latest build, and by uploading the latest build does it also correct all the issues from previous builds. ?? Sorry quite new to this tech stuff..
Thanks
geposted Sat 23 Aug 14 @ 12:10 pm
Advanced options: search checkUpdate, set to yes, the updates will fix what has been fixed.
