Had a quick search and couldn't find any other threads regarding this:
The panel button on the M6000 mk2 doesn't work on default mapping.
Had a rummage and saw that the default script running on that button is:
skin_panel "mixer" on ? skin_panel 'video' on : skin_panel 'video' on ? skin_panel 'scratch' on : skin_panel 'mixer' on
but for it to work, I've had to change it to this:
skin_panel "audiomixer" on ? skin_panel 'videomixer' on : skin_panel 'videomixer' on ? skin_panel 'scratchmixer' on ? skin_panel 'mastermixer' on : skin_panel 'audiomixer' on
not a massive issue but thought you might want to fix it in the next update
cheers
cheers
geposted Sun 24 Aug 14 @ 1:00 pm
Fixed in builds ending at 772 (or higher)
action changed to
skin_panelgroup 'mixer' +1 & skin_panelgroup 'center_pannel' +1
so that it will cycle through the panels of both ver7 and ver 8 skins
action changed to
geposted Sun 24 Aug 14 @ 6:22 pm
Mine's 1932.771,
how dyou get 772?
Is it not an automatic update?
how dyou get 772?
geposted Fri 29 Aug 14 @ 9:48 pm
actually we re on 784 at the moment. The last 3 digits of the software build indicate the controllers version. The controllers get automatically updated, if you just leave the software running (idle) for a few minutes (depending on your connection speed) and re-launch.
geposted Sat 30 Aug 14 @ 2:00 am
I think it may be because I was using a custom mapping? Either way, onto 794 now. Cheers for your help
geposted Sat 06 Sep 14 @ 3:29 pm
