Forum: Old versions
Topic: Headphone Out not working on DDJ SX
Hey Guys,
I downloaded the mapping for DDJ SX onto the Pro Version of Virtual DJ and everything works fine except for the headphone jack so I can hear the other decks and cue music up. It works fine in Serato. How can I fix the problem in Virtual DJ?
geposted Thu 28 Aug 14 @ 11:32 am
VDJ 8 or 7?
Just make sure you've configured the audio options correctly. VDJ 8 should detect and configure itself (in theory) and the info for VDJ 7 is in the wiki.
VDJ 7, I downloaded 8 and it works fine there as well as Serato. The reason I use 7 is it allows DRM.
If I follow the sound set up in the wiki for the controller it makes everything sound like it's going through a cheese grater
On 7? You may need to set the SX audio to 16 bit/44.1 (if poss via Pio configs) to get it working with 7, as 7 has issues with higher rates.
Awesome great thanks!
