Forum: Old versions
Topic: Some MP3 files won't load
Hi People, I have the free home version of Virtual DJ, I have converted some of my video with audio files into just MP3 audio, but one or two will either not load at all on to a deck, or will load but the Deck Waveform Display will not display properly, or at all. Could you help?
geposted Thu 28 Aug 14 @ 10:21 pm
VDJ 7 or 8? What did you convert them with? Do they play OK in other software? How long are the ones with the waveform issue?
Its Virtual DJ7, I used real downloader to convert a video file into MP3, I've tried various bit rates to no avail, the tune in question does play on other software Windows media player, but the song is unusually long 15.45 mins
I've just downloaded VDJ8 and although its to soon to determine if all is well, the tune I was having the problem with in VDJ7 now works ok in VDJ8.
Read this wiki entry (which is written for VDJ 7) - specifically the 6th bullet point.
I believe there is a setting in vdj7 that prevents waveform from displaying on long tracks over 15 mins. The waveform will appear as it is played though just not before.
Yes that's fixed the issue, thanks V much. Peace to all
