Trying to install the DJ Dad mapper for the NI Traktor X1 mk2. Put the .xml files in the Mappers and Devices directory. Shows up under FACTORY DEFAULT when I open CONFIG-->CONTROLLERS. Once I close the CONFIG window, software does not respond to controller. When I re-open the CONTROLLERS menu, it says custom mapping, but there are now actions listed.
Having the same problems with the F1. Also, can't a mapper to work for the Novation Dicers. MC6000 works fine so far.
15" MBP Late 2013; 16GB RAM; 1TB SSD; 4GB GDDR5; OS up to date.
geposted Fri 29 Aug 14 @ 11:15 pm
Controllers like the F1, X1 etc that dont offer a vid/pid under MIDI protocol will have an issue with version 8 as it cant rely on drivername in/out and needs a vid/pid. the specific unit (among other NI devices) only offer a "stable" protocol with vid/pid on HID, however we dont own any device at the moment in order to port these controllers on HID protocol, neither Native Instruments provides any information.
Bottom line, we have no solution at the moment
geposted Sat 30 Aug 14 @ 8:01 pm
Is one being worked on? Or SOL? Would be nice to use them with the new software.
geposted Sun 31 Aug 14 @ 9:29 pm
Checking in!!!
geposted Sun 07 Sep 14 @ 6:37 pm
