Forum: Old versions
Topic: Virtual dj laptop HDTV and Pioneer DDJ-WeGO2 Combination
Hey, being looking at getting a dj controller and will probably go for the Pioneer DDJ-WeGO2
if it will do the job i need it to. My current set up is Virtual dj installed on laptop with laptop connected via HDMI to a HDTV and headphones out from the laptop jack out. The HDTV displays the laptop screen and gives master audio out through its own speakers. What i need to know is, if i connect up a DDJ-WeGO2 via usb will i still be able to hear the master out from the tv or will this setup re route everything for me? I want the controller to simply take over the controls and leave everything else as is.
geposted Sat 30 Aug 14 @ 1:43 pm
If you just try to operate VirtualDJ with the bundled VirtualDJ 7 Limited Edition (which comes with newly purchased WeGO2), then it will only allow you to have Master Output and monitoring (Headphones) through the outputs of the WeGO.
If you upgrade to Pro Infinity or purchase a PLUS License (version 8 only), you will be able to route both Master Output and Headphones channel to whatever sound output you want.
Thanks for the reply that's great to know I have that option now.
I wanted to know how do i connect the master output to external speakers, what type of rca cable do i need, rca with 3.5mm jack or rca to rca? I only have the 20 trial ddj wego2 virtual dj but how do i configured the sound so i can here the cue headphones and the master speaker output playing from the external speaker at the same time?
