Discussion about Denon MC 3000 Enhanced VDJ8-Mapping by djragman
Description:
SPECIAL FEATURES:
ENGLISH:
(Deutsch im Anschluss)
EFX-SECTION:
EFX 1-Button: Custom Effect active
EFX 1-Slider: Custom Effect Selection
Shift + EFX 1-Slider: Selected Custom Effect-Slider 1
EFX 2-Button: Reverb active
EFX 2-Slider: Reverb Slider 1
Shift + EFX 2-Slider: Reverb Slider 2
EFX 3-Button: FlangerHQ active
EFX 3-Slider: FlangerHQ Slider 1
Shift + EFX 3-Slider: FlangerHQ Slider 2
EFX 4-Button: Loop Roll active
EFX 4-Slider: Loop Roll Slider 1
Shift + EFX 4-Slider: Loop Roll Slider 2
FX 1-Button: Effect 'Beat Grid' while pressed, Shift + FX 1-Button: Beat Grid-Slot -1
FX 2-Button: Opens/Closes Beat Grid-Effect-GUI, Shift + FX 2-Button: Beat Grid-Slot +1
Sampler-Buttons Left Deck: Famous Sampler-Pads 1-4
Sampler-Buttons Right Deck: Famous Sampler-Pads 5-8
LOOP-Section (only Special Features listed):
Shift + Loop -: Changes Key -1
Shift + Loop +: Changes Key +1
Shift + AutoLoop: Changes Key to 0
MIDDLE-SECTION:
Browser-Button: Open Automix in Sideview
Sampler-Button: Open Sampler in Sideview
Effect-Button: Open GUI of the selected Effect in Sideview
Record-Button: Open Config-Menu for Record
Track-Button: Load song, Shift & holding Track-Button >500 ms: Add Song to Automix
Back-Button: Browser window -1, Shift + Back-Button: Sideview window -1
Fwd-Button: Browser window +1, Shift + Fwd-Button: Sideview window +1
Load A/C-Button: Load selected left deck, Shift + Load A/C-Button: Unload selected left deck
Load B/D-Button: Load selected right deck, Shift + Load A/C-Button: Unload selected right deck
MIXER-SECTION:
Filter-Slider: Filters V2 TexZK
PLAYER-SECTION:
KeyLock-Button: KeyLock, When holding KeyLock-Button >500 ms: Pitch Reset to 0%
Play: Play/Pause, when holding 1000 ms Player goes to the beginning of the track, Shift + holding 1000 ms Player goes to Cue 1
Cue: Cue Stop, Shift + Cue-Button: Effect 'Backspin'
Vinyl-Mode-Button: Vinyl-Mode, Shift + Vinyl-Mode-Button: Effect 'Brake'
NEEDED Plugins:
Filters_V2: http://de.virtualdj.com/addons/4294/Filters.html
Loop Roll: http://de.virtualdj.com/addons/12952/LoopRoll.html
BrakeStart: http://de.virtualdj.com/addons/13338/BrakeStart.html
DEUTSCH:
EFX-SECTION:
EFX 1-Button: aktiviert Custom Effect
EFX 1-Regler: Auswahl Custom Effect
Shift + EFX 1-Regler: ausgewählter Custom Effect-Regler 1
EFX 2-Button: aktiviert Reverb
EFX 2-Regler: Reverb Regler 1
Shift + EFX 2-Regler: Reverb Regler 2
EFX 3-Button: aktiviert FlangerHQ
EFX 3-Regler: FlangerHQ Regler 1
Shift + EFX 3-Regler: FlangerHQ Regler 2
EFX 4-Button: aktiviert Loop Roll
EFX 4-Regler: Loop Roll Regler 1
Shift + EFX 4-Regler: Loop Roll Regler 2
FX 1-Button: Effekt 'Beat Grid' solange Button gedrückt wird, Shift + FX 1-Button: Beat Grid-Slot -1
FX 2-Button: öffnet/schließt Beat Grid-Effect-GUI, Shift + FX 2-Button: Beat Grid-Slot +1
Sampler-Buttons linkes Deck: Famous Sampler-Pads 1-4
Sampler-Buttons rechtes Deck: Famous Sampler-Pads 5-8
LOOP-Section (nur die Special Features gelistet):
Shift + Loop -: Tonartwechsel -1
Shift + Loop +: Tonartwechsel +1
Shift + AutoLoop: Tonartwechsel zu Original-Tonart (= 0)
MIDDLE-SECTION:
Browser-Button: Öffnet Playliste in der Sideview
Sampler-Button: Öffnet Sampler in der Sideview
Effect-Button: Öffnet das GUI des ausgewählen Effektes in der Sideview
Record-Button: Öffnet das Aufnahme-Konfigurations-Menü
Track-Button: Lädt den Song, Shift & Track-Button >500 ms gedrückt halten: Fügt Song der Playliste hinzu
Back-Button: Browser-Fenster -1, Shift + Back-Button: Sideview-Fenster -1
Fwd-Button: Browser-Fenster +1, Shift + Fwd-Button: Sideview-Fenster +1
Load A/C-Button: Lädt Song in das ausgewählte linke Deck, Shift + Load A/C-Button: Wirft Song aus ausgewählten linken Deck
Load B/D-Button: Lädt Song in das ausgewählte rechte Deck, Shift + Load A/C-Button: Wirft Song aus ausgewählten rechtem Deck
MIXER-SECTION:
Filter-Regler: Filters V2 TexZK
PLAYER-SECTION:
KeyLock-Button: KeyLock, wenn KeyLock-Button >500 ms gedrückt wird: Pitch Reset to 0%
Play: Play/Pause, wenn Play-Taste >1000 ms gedrückt wird, springt der Player zum Song-Anfang, Shift + wenn Play-Taste >1000 ms gedrückt wird, springt der Player zu Cue 1
Cue: Cue Stop, Shift + Cue-Button: Effekt 'Backspin'
Vinyl-Mode-Button: Vinyl-Mode, Shift + Vinyl-Mode-Button: Effekt 'Brake'
BENÖTIGTE PLUGINS:
Description:
SPECIAL FEATURES:
ENGLISH:
EFX-SECTION:
MIDDLE-SECTION:
MIXER-SECTION:
PLAYER-SECTION:
NEEDED Plugins:
DEUTSCH:
EFX-SECTION:
MIDDLE-SECTION:
MIXER-SECTION:
PLAYER-SECTION:
BENÖTIGTE PLUGINS:
geposted Mon 01 Sep 14 @ 1:34 am
