angelt99 wrote :
No it not just the display when i move the pitch faster or slower on the turntable u do not here the change on the turntable to the software catches up then u here the change so if u are mixing and slightly move the pitch from the turntable to match the song playing it not matching u have to keep moving the the pitch slider up and down alot pass - & +until the software catches up so say i am mixing a beat that 128 bpm and the song that is playing is 129 bpm i have to move the turtable pitch slider almost pass - & almost pass + so the software catches up. So it not just the display .and do u have turnbles so u can hear the difference.and if u do go to the pitch slider on the turntables and move it all the way up and all the way down and u see it take virtual DJ a second to catch up. And
Because of the second to catch up u do not stay on point with matching the song that's playing. Do u want me to make a video about the issue so u can see for your sell?
Adion wrote :
No, the change is applied instantly, but the display takes some time to update, exactly to make sure that it is stable and isn't moving while doing corrections.
You don't hear it because it uses master tempo to make short corrections (same as pitch bend buttons without vinyl control)
geposted Sun 07 Sep 14 @ 5:39 am
The corners of the pitch graphic are not completely clean smal white dots.
Prev.player stop playback always on one Track Stereo 44100Hz 32bit Bitrate 254 mp3
geposted Sun 07 Sep 14 @ 6:48 am
so how are u suppose to mix then it does not stay on point .when u are mixing and u move the pitch silder on the turntable and it get on point with the song thats playing and vdj finally catch up u get off beat and move the pitch again on the turntable and get on point and then the pitch slider on the software move u get off beat again.no disrespect but u are putting like u don't no how to mix or what i am talking about even if are using the sync button it does the same thing. so i do not no what u talking about. And u never answer my question do u use turntables ? if u do u wood know what i am taking about.
geposted Sun 07 Sep 14 @ 10:56 am
2X had aCrash but no Crashguard report in folder with no controller hook up .This time this was 1st
OSX 10.9.2 / 2.6Ghz i7/ 8Gb RAM
geposted Mon 08 Sep 14 @ 12:46 am
[MAC OSX]
by the way... i don´t work with crossfader and would make it "disable" on DJ DAD Combat Mirror Skin, but after a time, the crossfader option return automatic to "use"
I´m very surprice because one deck was very quite
now i delete the crossfader function in main mapper option, but this is not correct.
... i think this is since the last beta...
geposted Mon 08 Sep 14 @ 1:43 am
I'm sorry, but as time passes and the improvements do not come ...
continuing problems with vdj8 Mac & NS7II,
automix that stops by itself, with a restart of the software, and editor of tags that still does not work with video mp4, and perhaps also other problems
professionals who live with us for our work this is not acceptable, and software competitors are moving forward ...
geposted Mon 08 Sep 14 @ 6:40 am
@ ErikVeejay And how does all that relate to regression bugs for a build that only focused on timecode? (Rhetorical question because it doesn't.)
The automix issue can be resolved by turning repeat on.
geposted Mon 08 Sep 14 @ 7:05 am
Mr_T wrote :
[MAC OSX]
For now, i would suggest to delete the action of the XFader Curve knob of your controller or assign it as ..
crossfader_curve 'disabled' ? nothing : crossfader_curve
We ll try to find a nicer solution for this case, but please dont post this here..nothing to do with the recent builds.
geposted Mon 08 Sep 14 @ 9:19 am
motorWheellinstantPlay not work
geposted Tue 09 Sep 14 @ 12:32 am
We also confirm with my NS7II
motorWheellinstantPlay not work correctly (has a short slow start)
geposted Tue 09 Sep 14 @ 3:52 am
change MotorWheelLockTime to 0.1 instead of 1,worked for me on the stanton scs1d.
geposted Tue 09 Sep 14 @ 2:07 pm
not work in 3700 denon motorWheellinstantPlay
geposted Tue 09 Sep 14 @ 6:26 pm
Not work on Numark NS/II
geposted Wed 10 Sep 14 @ 2:29 am
With numark NS7II adjusting the speed of departure does not work!
the song increases very fast and then come back at the right speed
geposted Wed 10 Sep 14 @ 12:50 pm
startupspeed and brakespeed indeed need some tweaks. Team is aware of.
geposted Wed 10 Sep 14 @ 3:11 pm
