Forum: Old versions
Topic: One Laptop, 2 pioneer dj-sb, 2 djs.....
How do i configure the settings to have both controllers to have separate cue monitoring... controller djsb-1 for decks 1,2 and djsb-2 for decks 3,4 ?
geposted Wed 03 Sep 14 @ 8:18 am
You will probably see 2 DDJ-SB devices detected in the CONTROLLERS tab of Config (left side window). You will then need to choose the first one and make sure the Deck assignment is at decks 1,2 and then select the 2nd one and assign to deck 3,4
However, keep in mind that both units will control the crossfader, so it would be preferred to disable this (from the Mixer Options of the default 4 decks).
One other thing is which sound card you will use. Not sure how the audio configuration will handle this. We dont have 2 identical units here to test. Apparently it will be Master & Headphones again, but really not sure which one of the 2 will use ..(or both ?) so this is something that you need to figure out (and post feedback if possible)
