Unable to configure custom button for HideSongInfo,
Mid 2012 OSX 10.9.4, Processor 2.6 GHz Intel Core i7, Memory 8 GB 1600 MHz DDR3, Graphics Intel HD Graphics 4000
Current 8.0 build 1949.792 although hasn't worked in the previous builds either.
geposted Thu 04 Sep 14 @ 7:32 am
you can't, you need to change this command in the xml file
geposted Thu 04 Sep 14 @ 8:08 am
No. It's working on Win.
Action is
setting "hideSongInfo"
Tested it myself, works.
So, seems to be a Mac bug.
Action is
geposted Thu 04 Sep 14 @ 8:18 am
@Scorchin try use this on a custom button
setting "RPM" 10
does it slow the platter's RPM? (Just trying to work out if it's all settings that macs struggle with or just Hide)
setting "RPM" 10
geposted Thu 04 Sep 14 @ 8:50 am
The real option doesn't have caps in the word "hide". Options are case sensitive.
geposted Thu 04 Sep 14 @ 10:34 am
@ fruit, they're not, at least they aren't here, HIDESONGINFO|hidesonginfo|HiDeSoNgInFo all work.
(I don't know why options are piggyback spaced but I kind of like it) #totalNerd
geposted Thu 04 Sep 14 @ 12:05 pm
Right, my bad.
geposted Thu 04 Sep 14 @ 5:08 pm
setting 'HideSongInfo' action assigned to keyboard, controller and custom buttons works fine on Mac as well (and not case sensitive either)
geposted Thu 04 Sep 14 @ 9:07 pm
Please pay attention, that there is no "s" in this setting-script.
There are these two actions "settings" and "setting" but for this script the one without the S is needed.
So like above: setting "hideSongInfo"
geposted Fri 05 Sep 14 @ 3:08 am
Thanks, got it, I wasn't putting "setting" in the action window before "hideSongInfo"
Cheers..
Cheers..
geposted Fri 05 Sep 14 @ 7:56 am
Doh!
geposted Fri 05 Sep 14 @ 8:46 am
