Topic: virtual 8 et gémini g4v
Ma gemini g4v ne fonctionne pas correctement avec virtual dj 8 , les leds lumineux ne s'allumes pas et d'autres fonctions ne marche pas , HELP
geposted Thu 04 Sep 14 @ 11:28 am
He is saying that his gemini g4v controller isnt working properly with the virtual dj8 software (including the LED's)
Im having the same problem unfortunatly and am getting frustrated in trying to find a solution as ive spent 440 quid on the kit and software. i love the quality of the software but am finding it difficult to map and fix to work properly with my controller, any help you guys can provide would be much appreciated.
I have this problem
Did you update the firmware, as per the post before yours?
