Hey all,
I've been playing with freestyler for a day and a half now and have created a few scenes that I now want triggered during specific songs.
I have watched the DJ Cheers videos numerous times and I think I'm doing everything right but when the cue point comes and goes nothing happens.
Is there some documentation on this plugin that explains how it works?
I have created the cue point and called it fs: 272,255 as the video tells you to but nothing is happening.
Any direction would be most appreciated. I am doing this in Virtual DJ Pro
Thanks
Thanks
geposted Sat 06 Sep 14 @ 5:41 pm
Just a followup.
I have since realized that DJ Cheers video is wrong. There is no space after the : and when you are running vdj and freestyler on the same PC I understand that the command should be fs:272,1
I have done that.... no lights...
To confirm I have dropped the same lighting program into the page_1 view on the cue section in freestyler and each one starts the lights no problem when they are clicked directly. But they get no lovin' from VDJ
I have also turned off Windows Firewall and this is in VDJ 7 Pro (7.4.1)
Any help would be most appreciated. I've spent the whole day on this.
geposted Sat 06 Sep 14 @ 6:40 pm
So just to confirm:
You've installed this plugin:
https://virtualdj.com/addons/15834/freestyler.html
and in the plugin settings you've enabled "Monitor Cue Points", then created a cue point with the name FS:272,1 which will send the command "Toggle Cuelist 1".
Have you tested to see if the grid gets passed as sound to light trigger?
geposted Sun 07 Sep 14 @ 8:59 am
Thank you SOOO much for responding :)
Yes, that is the plugin I've installed.
I have not performed that test. Can you tell me how to do that?
geposted Sun 07 Sep 14 @ 9:09 am
Make sure you have something in FreeStyler set up to react to "Sound to light" then enable "Monitor Grid" in the FreeStyler plugin. Play a song and see if FreeStyler reacts.
You could always try the network method too - enable the network and set the IP address to 127.0.0.1.
geposted Sun 07 Sep 14 @ 10:56 am
Ok S2L with monitor grid WORKS.
I also have the network set to 127.0.0.1
I have upper cue point set to 99. VDJ says it is monitoring cues 1-99
I have mapped the letter 'A' key to mark cue 5 and have set_cue 5 & cue_name as the action in mapper.
When I hit A it asks me to enter the cue name and I enter fs:272,1
geposted Sun 07 Sep 14 @ 11:39 am
SOLVED
fs must be CAPATALIZED!
FS:272,1 is he correct syntax. fs:272,1 will NOT work.
So..... I spent 5 hours yesterday troubleshooting.... capital letters. sigh.
Anyway, so happy to have figured it out.
I may record a HOWTO video after this ordeal.
Thanks for helping out!
geposted Sun 07 Sep 14 @ 11:41 am
