Forum: Old versions
Topic: Software RIAA
Ok, so where is the option to enable software riaa filter when using time codes?
If it's all automatic it's doing a very poor job at detecting the signal, mix vibes cross and mixxx both have no trouble finding the signal.
I honestly think virtual dj 8 is a big step backwards, I can't find any options to do anything. Hell, I can't even find out where to change timecode options from 33 to 45 rpm. Can't find where iTunes playlists are located. At this rate, I'll be unsubscribing pretty damn quick.
geposted Sun 07 Sep 14 @ 12:27 am
So I found in the manual that virtual dj 8 does not have a software riaa preamp. And yet virtual dj 7 does. Not to mention that once I got it to work the dvd randomly flips into reverse while the signal is perfect and stable in mixxx. I will be unsubscribing, a new version is meant to be better than an old version.
Where is the option for activating software riaa?
