Hi everybody . i Bought Virtual Dj 8 and i just tried it with launchpad s for use samples and play live too.
can we play samples/loops from LP s in SYNCH ? Like Ableton live?
I mean ,when i push for play a beat (loop) it start when the other song (loop) finish for be in good SYNC... this is in Ableton live
In VDj 8 you push all kits/songs/loops and they start when you push it...so it's very difficult to use LP s because the songs or loops don't start at the first beat of the others loops who are playing...
maybe there is one way to avoid this. thanks :)
geposted Sun 07 Sep 14 @ 1:29 pm
On their own samples don't sync (because there is nothing to sync to), BUT if you have a track playing on any deck, the samples will beat sync with that track, so if you have a track playing but have the Upfader for that deck down, then it works.
geposted Sun 07 Sep 14 @ 5:35 pm
