Forum: Old versions
Topic: Behringer BCD3000 Buttons w/ LEDs
Hello all
Since upgrading to VDJ8 any button with an LED on my controller must be pressed 2-4 times to actually set the effect/loop/etc and it's been becoming a larger pain by the day. Know of anything I can do? I would like to press effect/loop and have the software respond on that first attempt again.
Thanks!
geposted Sun 07 Sep 14 @ 5:22 pm
Any help here, please? This problem affects my play buttons and EQ Kill buttons as well
Goto COnfig->Controllers tab.
Select the BCD3000 from the top list.
Select the "factory default" from the Mappings drop down list on the right side.
Press the LOOP button on your controller (or any other button that needs twice to be pressed)
You should then see this button at the bottom left area (Keys). Do you get that or still has to be pressed twice ?
Post a screenshot of the Controllers window here please.
